주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Screen not turning on
After screen replacement my screen won’t turn on. The phone was switched of and the repair was done. When the new screen wasn’t working I tried putting the old cracked one back on it but it didn’t work either. I’ve done lots of screen replacements but have never come across this problem. I have tried everything but cannot find any fixed please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I’ve tried using a flashlight too see the screen but I cannot see anything but the phone is turning on because I can hear the noise from charging the phone and it vibrates when putting ot on silent
댓글 달기
답변 1개
선택된 답변
Did you forget to unplug the battery?
Backlight failure is a very common issue on the 6s models in particular because of the 4V pin and the ground pin on the LCD connector being next to each other can can be shorted easily when connecting or disconnecting the screen with the battery plugged in (even with the phone and screen turned off).
Usually you will see a puff of smoke near the screen connector when this occurs.
To confirm backlight failure, turn the phone off and use a flashlight to see if you can see a dim apple logo on the middle of the screen, additionally you could connect the iPhone to a computer and open up iTunes to see if the phone successfully boots up and is detected by iTunes.
To get backlight circuit fixed, that requires someone to do micro-soldering on the phone (basically repairing the backlight circuit and components on the logic board).
I would estimate about $80-$150 for the job to be done.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Then it's either a faulty screen or micro-soldering need to be done on the board at least.
TL:DR - Phone most likely needs to be looked at someone that does micro-soldering to troubleshoot no display / backlight issue if multiple screens have been tested already on the phone.
Alright okay, thanks.
댓글 달기
귀하의 답변을 추가하세요
Haris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 95
