주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
What could three MacBooks go unresponsive in one month?
Three macbooks have gone completely unresponsive in one month in our household. The magsafe indicator is faint and just dies out slowly when you plug it in. We have been using the same OEM charger on all laptops, plugged into the same extension cable. Gradually, all three macbooks would suddenly not turn on anymore and not respond to ANYTHING.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sounds like a killer charger. I would avoid using it and find an original one, even if used.
Don't buy a "genuine" from China, they usually sell garbage in a fake shell.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Any of these could be faulty
  1. Mag charger (Get another or Borrow one you know working to test).
  2. Extension lead (Bypass & use the wall)
  3. Internal problem with electrics in house.
  4. External power issue, cuts, spikes & surges.
You really should be using the proper power supply from apple.
Not all apple laptops using the same wattage magsafe(s). Unless of course they are all identical models.
Extension leads should have built-in surge protectors.
Which should be replaced every 5 years.
If the macbooks in question don't have separate power circuits from the main logic board it is more than likely you have spiked them all. Toasted the main boards.
It goes without saying domestic electrics is dangerous.
Get a professional.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Timothy Barson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 51
