주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Voltage spikes from lightning connecter
A few days ago I checked the voltage on a broken iPhone 6s at the battery connector on the main board when charging and it had like these weird spikes, and it started at 2V and then it immediately dropped to 0V and then reset, I tried to take the measurement both with and without a 1M ohm resistor but it gave me the same results. I checked a working iPhone 6 (as I don't have another 6s) and checked the voltages on that one too and it was more stable, which lead me to believe that the charging port was faulty. I have now changed the charging dock and I have the same problem. Any ideas of why I get these spikes or if it is normal?
Cheers
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Could be many things on the logic board, Tristar, PM ic, short on CPU caps, or the CPU itself.
Needs board-level repair / microsoldering work done on this to fix at least.
With a DC-bench power supply and the adaptor to plug into the battery connector you can do better troubleshooting there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hey, thanks for this answer! Is this so for all boards where the charging acts like that or is that just because I changed the port and it acts the same way?
Charging ports don't really cause these issues.
댓글 달기
my mind its cpu, I had already the same issue, every things went ok, but when I checked in diode mode around cpu,, it was 113 .
its under the threshold for a semi conductor the I think its a cpu short. ..!!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Lasse Falch Sortland 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 145
