Side buttons stopped working after cleaning the inside of the mouse
Hi
I opened my mouse to clean it and improve the main right & left click buttons,
The cable that connects the two parts of the mouse got loose from its contacts,
I put it back in, but then then the side buttons stopped working such as the DPI + back & forth button & the big hidden button
I tried connected this cable both sides again in different position, not sure which is suppose to be up or down, seems the cable connectors have already eroded from all this "play", also the charge light on the side is not on anymore, so basically the circuits on the left part of the mouse are not functioning
Other then that, the main right & left click and scrolling etc. all work fine
Any solution ?
Thank you
좋은 질문 입니까?
@acetrip add a couple of GOOD pictures of the "connected this cable both sides again in different position, not sure which is suppose to be up or down, seems the cable connectors have already eroded from all this "play", also the charge light on the side is not on anymore," with your QUESTION. That way we can see what you see.
oldturkey03 의
im sorry but u shorted something by cleaning it or puting it the wrong way
Ayden Aldrich 의
Ayden Aldrich so what's the fix? How can you help the OP repairing his device? How does your answer help the OP?
oldturkey03 의
