주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone Not Turning On After Using Cheap Wall Charger
I had a fully functioning iPhone 6s until a few days ago. Will traveling with my family, my dad brought a wall charger that we later found to be faulty after my phone died. The minute I plugged the charger into the outlet to charge my phone, it first froze and then died.
I have tried multiple steps to try to bring the iPhone back to life. I would do a hard reset, but that wouldn't work. Honestly, my iPhone has no signs of life thanks to the faulty wall charger. What can I do to fix this problem? Is the logic board officially fried and therefore unusable?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Could be one of many things or could be a combination of them:
- Charging port and battery blown (You would need to replace both at the same time to get the phone to work properly)
- Battery gone bad from faulty wall charger (Battery just needs to be replaced if that's the only part faulty)
- Charging chip, power management chip gone bad (Tristar, board-level / microsoldering repair)
- Main processing chip gone bad, if this is the case the phone is basically paperweight.
- One or more capacitors near the main processor chip shorted (in this case they usually get removed and if needed replaced as well).
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Ben I'd say you've gone a little too far :)
Using a non-original charger causes a malfunction in the motherboard that is connected to the U2 component.
Throw away the charger, go to a professional lab to replace the component.
Use only original charger % cable! also in the car(greffen approved by apple - car charger very good!)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Makhwarand Khan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 208
