주요 콘텐츠로 건너뛰기
모델 M7572 / 400 또는 500 MHz G3 프로세서
PowerBook G3 Pismo wont power on and smells funny
I have a wonderful Pismo, it has been working great, i replaced many parts and havent had any issues in the last 2 years. The hocky puck charger adapter was sparking and not charging so I purchased a non-puck replacement and plugged it in and let it charge, the next day pismo turned on just fine and about 2 minutes later it made some weird sounds like a spinning disc being stuck or something the screen froze and then it shut off. It had a elecrtical burn smell, I couldnt get it to turn on again. Not sure what part needs to be replaced, if its from one of the chargers or something else. Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Your hard drive may have locked up. Try removing it and starting up from your system installation disk. If it starts up from the disk without the hard drive then replace the drive. Here's how to get to it: PowerBook G3 Pismo Hard Drive Replacement
Also what was the wattage on the original charger and the wattage on the new one?
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
The wattage on the old one is 45watts the new one says output is 24volts so I dont know. I ordered the that said it was the charger for the Pismo, I didnt think to really look into wattage. I will try removing the hard drive next and will let you know what happens.
댓글 달기
답변을 추가하세요
Sabrina Fairclough 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 820
