주요 콘텐츠로 건너뛰기
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 질문 전체 보기
Green lines across my images
I purchased a Canon 70D over eBay and on all the manual settings, the images have two solid green lines across them. This could indicate a possible sensor problem, however, if I shoot on Automatic the lines are not there - could this be possible?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Had a similar problem with a 5D MKIII, replaced the Sensor Ass'y, Main PCB & Mirror Drive PCB with test parts and didn't fix it, figured Main PCB was corrupted so downloaded and installed Magic Lantern (only on the memory card) ran the test's it comes with and fixed !!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Change the aspect ratio of raw images to 3:2 or the default that it came with and you can crop it latter
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nell Delport 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 6
전체 시간: 1,004
