주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Flashing folder and SSD not showing in disk utility
So that basically sums it up, my SSD doesn't even show up when using internet recovery's disk utility and when I finally decided that just buying a new SSD at Best buy($67 for comparable 250gb size drive? Awesome!) and reinstalling macos would be the least painless fix I found out that it's not that simple. So I'm wondering if there is something else I should try to attempt to fix this drive that could be making it not show up in disk utility, terminal commands or the like and if they are possible to do with only being able to load into internet recovery at the moment?
Thank you for your time and patience! Dealing with this has brought me to my favorite barstool where I am currently typing this and I hope that what I'm told is already an odd manner of speech hasn't become more.. well odd/confusing.
Thanks again
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The SSD you bought is not an Apple Brand right? Most of us have found the blades made for PCs are not stable or just don't work, Try one from OWC.
https://eshop.macsales.com/item/OWC/S3DA...
MacBook Air 11" (2013-2015) 13" (2013-2017) MacBook Pro Retina 13" and 15" (2015) SSD
MacBook Air 11" (2013-2015) 13" (2013-2017) MacBook Pro Retina 13" and 15" (2015) SSD 이미지
상품
$39.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Dave Nolan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 836
