주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
405 질문 전체 보기
Audio not working. Think I blew something up.
I had the speaker output from my stereo going into the line input jack on my MacBook and I accidentally turned up the volume way too loud and the computer just shut off.
When I went back in, I checked the input section in settings and nothing was there, nor were there any outputs and when I played a youtube video, no sound came out.
So does anyone know what I blew up, where it is and how I can check it?
TIA
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Does the audio port have a red light in it?
댓글 달기
답변 1개
선택된 답변
I would first try resetting Pram and Smc, in case it is just a glitch. If those don't give you your sound back, it's basically useless to open the Mac searching for blown components.
Audio input is filtered by resistors and capacitors, but if you have no output sound either it means the filter system got crushed and possibly a surge went all the way up to the audio codec.
There are tenths of components involved there and nothing replaceable without testing and soldering.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
OK. Ill try that then. I m almost positive its a surge and not a glitch because the volume was turned up WAY to high and it just shut off. Im pretty sure I blew something up. Im thankful though its just part of the audio because this is a laptop I use in school and its not very often I use sound
댓글 달기
귀하의 답변을 추가하세요
Cameron 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 157
