주요 콘텐츠로 건너뛰기
Coffee brewer released in 2013. This specific Keurig can be identified by its model number K70 listed on the bottom plate of the brewer and is a single cup brewer.
8 질문 전체 보기
Need disassembly instructions to replace Keurig K70 air pump
Partial cups of coffee. Done the easy and usual: clearing the puncture pins of debris, filter at bottom of reservoir, descaling with vinegar. Now I am convinced it has to be a weak air pump.
I'm looking for a way to remove the guts to get access to the air pump. I'd like the results to be cosmetically pleasing, so the hacksaw solution is not acceptable.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
3 댓글
I have the same problem? Any answers yet?
Sorry to say, I put that Keurig in a bag on the shelf in the garage awaiting some further inspiration. I have not had progress, other things became more important. Probably end up buying a new one…. I have been using a smaller Keurig labeled with Mr Coffee logo and that one, too has started has started to make 1/2 cups… Common fixes don’t work for that one any longer Gee Whiz….
Nobody knows how to take a keurig apart? I might as well tinker blindly! Will post if I have any luck.
댓글 달기
답변 1개
가장 유용한 답변
Here’s a video on how to fix it:
xhttps://www.youtube.com/watch?v=CuczMT3R...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Been there and agree that’s the problem, but there is no instruction about how to remove the guts to expose the air pump for replacement!
댓글 달기
귀하의 답변을 추가하세요
Eric Andersen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 12
전체 시간: 1,024
