주요 콘텐츠로 건너뛰기
1.83 GHz Core Duo 또는 1.83, 2, 또는 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 질문 전체 보기
After replacing the hard drive, the LCD lights but shows nothing.
Disk Utility indicated mechanical failure in the iMac internal hard drive: "back up everything you can." I installed a new hard drive, but when I turn on the iMac I immediately got a solid white screen.
I booted from an OSX install disk, but still got the same solid white screen.
I started it up in FireWire target disk mode, connected to a MacBookPro. Using Disk Utility on the MacBookPro, I was able to eject the OSX install disk from the iMac. I was also able to successfully install OSX Snow Leopard on the new hard drive in the iMac. But even in target disk mode, the iMac screen remains white - no blue screen with yellow target disk icon.
Now the iMac boots up fine, I hear the "Welcome to OSX" music (doot doot da do-do) but the screen is solid white.
I reset the parameter RAM 7 or 8 times. I've checked all cables inside the iMac. I booted up in safe mode and verbose mode. Always the same result - everything works, but nothing appears on the iMac screen - no spinning startup wheel, no question mark, no text in safe mode. The display lights up, but nothing appears on it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Unplug all peripherals, unplug the machine, press and hold the power button for 10 seconds. Plug it back in and give it a try. If this fails, plug it into an external monitor to try to isolate the problem.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Unplugging everything and following the above steps: no change.
However, I finally obtained a MiniDVI to VGA adapter, and the remote monitor works fine.
The main screen is still solid light gray all the time...
I appreciate your help!
댓글 달기
귀하의 답변을 추가하세요
mickman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,789
