์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
Kindle Touch(D01200)๋Š” Amazon์—์„œ ์ƒ์‚ฐํ•œ 4์„ธ๋Œ€ Kindle e-๋ฆฌ๋”์ž…๋‹ˆ๋‹ค. Wi-Fi ๋˜๋Š” Wi-Fi/3G ์—ฐ๊ฒฐ์„ฑ์„ ์ง€์›ํ•˜๋ฉฐ, ๋ชจ๋“  ์—…๋กœ๋“œ๋Š” USB ์ผ€์ด๋ธ”์„ ํ†ตํ•ด ์ˆ˜ํ–‰๋ฉ๋‹ˆ๋‹ค. 4GB์˜ ์ €์žฅ ๊ณต๊ฐ„๊ณผ 2๊ฐœ์›”์˜ ๋ฐฐํ„ฐ๋ฆฌ ์‚ฌ์šฉ ์‹œ๊ฐ„์„ ์ œ๊ณตํ•ฉ๋‹ˆ๋‹ค.
My power button does not work
Power button does not work, e-reader appears to work correctly once started via USB cable into a PC but no other method that I have seen put forward in various articles seems to work including multiple resets, pressing power button for 7, 15, 30 secs. disabling screensaver etc. Guessing this has to be a hardware problem, but if anyone had any other suggestions or options to try before I dismantle this great bit of kit, please let me know. Thanks
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
Go ahead and take it apart it's easy just remember how the screws are placed. Then remove the battery and remove the front panel. After that go ahead and gently press the power and the home button with your screw driver. When you remove the motherboard there is going to be a square with four pins. Go ahead and clean this square. After that screw everything back how it was and your kindle should work.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
The Dan826 ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 6
์ง€๋‚œ 30์ผ: 49
์ „์ฒด ์‹œ๊ฐ„: 648
