주요 콘텐츠로 건너뛰기
The Dell Inspiron 14-7437 is pre-installed with Windows 8, has 4th generation Intel Core processors and a 14-inch display.
8 질문 전체 보기
My laptop is not charging, help!
Hi,
My laptop stopped charging recently. It works when plugged in but says "1%, not charging. Power mode (plugged in)." My first response was buying a new charger but the same thing happened. So I thought it must be the power jack. I ordered one on ebay and replaced it today. But the same thing happened - 1%, not charging...help! What else could it be?
Thanks Magda
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Hi @magbrown? had you checked about the battery?
what are you doing while you have this issue? you doing anything resource intensive?
No, not at all. I’m just simply using my laptop whilst pugged in. When I unplug it the laptop imediatelly turns itself off :( Thanks
댓글 달기
답변 1개
Try replacing the battery, and/or the pins and cables connecting the battery to the power jack and motherboard.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The laptop is only two years old. Do you think it could be the battery? Thanks :)
댓글 달기
답변을 추가하세요
Magdalena Browning 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 331
