주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for desktop PCs manufactured by Lenovo.
Power supply replacement question
I have a pc that needs a new power supply. It's a factory Lenovo, nothing fancy... I also have several old computers laying around. I want to see if I can just use the power supply from one of those but I'd like to be sure about compatibility before I start experimenting.
The first pic is the one I want to replace
Is this a viable replacement ?
Thanks for your time!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
A big thanks to everyone who responded. My machine is back up and running like a champ!
댓글 달기
답변 2개
선택된 해법
Plug things in properly and go.the one you want to install meets the needs of the pc.if you start adding things that take more juice you will need a bigger one but they are everywhere,like ebay
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If the form factor is the same and it has the same or more output power than the broken one ( it does ), and it has all of the correct connections there is no reason why it wouldn't work.
Check the molex connectors, does it have enough? Does the molex connector that connects to the board match? It most likely does.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rep Tilicus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 216
