주요 콘텐츠로 건너뛰기
The second generation Rogue is a version of Nissan X-Trail and inspired by the Hi-Cross Concept to adapt to North American market.
Radio buttons on steering wheel not working
Radio buttons on steering wheel that allow you to change from one station to another work when car is simply turned on (engine not running), but don't work when engine is turned on. (Can't change from one preset station to another). Volume control works both ways and all other functions work just fine (touch screen, control knobs) in both situations. 2016 Nissan Rogue
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 7개
Have you ever been able to change the station presets while engine is on? If not, then this is likely a factory option. If so, then it is possible that your steering switch is broken. You could try scanning for codes, just incase.
Yes, we could change the stations from the steering wheel. And the volume controls on the steering wheel still work. In fact only this one feature has stopped working. Called Nissan and will be taking the car in for repair. They had no other suggestions.
Thanks for your input.
Every time I turn left that shuts off my radio and my DVD what could this be
Dudden Jim - I would say this mostly likely a short in the wiring harness between your steering wheel and the head unit. I would check on crutchfield.com in the FAQ I believe they have a solution for this problem.
Dudden Jim - sounds like the clockspring behind the steering wheel could be bad. Any repair shop should be able to test and replace if necessary.
댓글 2개 더보기
댓글 달기
답변 7개
선택된 해법
Check to see what is displaying in the center display on the dashboard between the tach and speedometer. The channel buttons will not work if you are displaying the settings page. Try changing it to MPG display.
이 답변이 도움이 되었나요?
점수 4
댓글 7개:
Tom, you are amazing and right on. No one at Nissan could figure this out. Thanks so much.
Yup, have 16 rogue couldn't figure it out, was frustrating new car only 26,000 miles and stuffs not working?? So googled finally came upon this genius and was correct!!!! Even in park would not change if I was on warning page, then changed to mpg and worked immediately!!! Bravo bravo!! Thank you
I just bought a used 16 Rogue and am having the same problem - but can’t quite understand how to implement this solution? How do you make it display MPG? When I turn on the ignition, it seems to just display “no warnings”, outside temp, milage, etc.
You're a genius. This worked
Wow!!! Thanks!!
댓글 2개 더보기
댓글 달기
That’s crazy but it worked on my 2016 Rogue! Thank you!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanx... My 2018 Nissan Sentra SV had the same problem. Very Helpful.
USB Flash Drive and Change Songs same thing. Changed Screen. Now it works.
댓글 달기
Shouldn't this be a recall item since it appear all Nissans eventually have this issue
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My sourge bottom is not working on my 2012 altima .is it a fuse or something else ? Radio is working fine but not from steering wheel !! Thank you .
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
On my 2014 Altima SL the volume will only go all the way up or all the way down and this happens in its own. It wouldn't work at all for a while . Also i can change the settings on my screen it only shows the nav can get the radio the show or my satellite radio nothing
댓글 달기
Thanks everyone! I just had my car serviced yesterday and was having this issue this morning. Fixed.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
2014 Nissan rouge steering wheel audio control do not work in 2014 Nissan Rouge
댓글 달기
Omg! This is amazing! That’s all it took! Genius.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
To the person that went to the Nissan dealership for service what did they do to fix it? I have a 2015 Nissan Rogue. The left side of my steering wheel Has my radio/phone controls. I noticed this morning neither are working. I did try putting my screen on MPG which is where it is now and that did not fix it. I just thought maybe since You said you took your car in for a repair and I thought maybe they told you what was wrong with it and you would share. Thanks!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have same problem with my 2015 rogue
댓글 달기
답변을 추가하세요
Bill Luftig 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 78
전체 시간: 106,212
