주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
Can I replace the trackpad on a Late 2013 15" MacBook Pro Retina?
My trackpad will work for about a minute or so after startup and then stops completely. Is it possible to replace this part? I don't see any parts or instructions on iFixit. Many thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 2개
가장 유용한 답변
While the Both the 13" & 15" models use the same procedure MacBook Pro 13" Retina Display Late 2013 트랙패드 교체 to gain access to the trackpad (technically a touchpad). The 13” model uses a different part MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad which won’t work in your 15” model.
You need this part: MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad.
@ajcooke01 - Replacing the full uppercase is not really needed here.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad 이미지
상품
$69.99
MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad 이미지
상품
$49.99
해당 답변은 도움이 되었습니까?
점수 5
댓글 4개:
I have found that just replacing the cable works fine. There is very little that can fail on the trackpad. MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad Cable
@mayer - Very true!
Please help. Macbook pro late 2013 edition trackpad = non responsive, keyboard response is delayed or non responsive. Can one replace just these 2 parts? Which other models are compatible if so. Where can I find replacement parts?
@margot23 - iFixit sells the trackpad, click on the correct part above 13" or 15" depending on your exact model.
댓글 달기
I bought a new upper case for my late-2013 15" MBP. It included the keyboard but not the trackpad. I'm hoping these instructions for the 13" MBP will be all I need to transplant the trackpad to my new(er) upper case. I have a new battery to install too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
@reezekeys - Why are you replacing the uppercase?
I had a few keys of my keyboard stop working. I went to Ebay to get another one but found an entire upper case with keyboard in excellent condition for $9! It had no trackpad though. I also needed a battery so I got one, and figured I’d do both jobs in one shot.
@reezekeys - I would also replace the battery as well. Just follow the guide to transfer the trackpad.
I needed the battery for a long time, you know how that goes! Then the tab and function keys on my keyboard stopped working.
댓글 달기
귀하의 답변을 추가하세요
gslive 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 16
전체 시간: 7,629
