주요 콘텐츠로 건너뛰기
MacBook, MacBook Pro 및 MacBook Air에 사용되는 AC 전원 어댑터. 잡아당길 때 안전하게 분리되는 자가-정렬 자성 커넥터를 사용합니다. 1 세대 (2006-2012) MagSafe 충전기는 약간 두꺼운 L 자형 커넥터가 있습니다. 45 W, 60 W 및 85 W 버전으로 제공됩니다.
"Battery is not charging" and no light
I have a mid 2010 Macbook Pro.
Its adapter suddenly stopped doing half of the work: it can maintain the battery at its percentage, but not increase its charge.
The OS icon says "Battery is not charging", with a lightning logo. The LED is off.
The same Macbook with a different adapter works perfectly. The same adapter on another Macbook displays the same behavior.
Thus it seems pretty clear that this is specific to the adapter.
Any idea what is wrong and how to fix it ?
Thanks in advance
SOLUTION : I replaced the cable and now it's working
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Apple power adapters are garbage, they fail all the time in my experience.
댓글 달기
답변 5개
선택된 해법
Thanks for your answer ! In the end I replaced the cable, and that fixed the problem. Really weird.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Not much you can do here other than replace the power adapter.
Apple doesn't offer any internal parts and the unit is sealed.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
What is wrong?
If MagSafe power supply is identified as null and zero, then MacBook embedded controller does not allow charging of main battery.
Open 'System Information.app', view 'Power' (subpage of 'Hardware'), look under heading 'AC Charger Information:'. For an idea of what 'AC Charger Information:' looks like, a clue as to what to look for, here is a screenshot. Pictured is a full 'Power' report; near bottom is 'AC Charger Information:'.
MagSafe ID is zero
Does your Mac report information from its power adapter, or does it display all fields as zeros?
If your subject power adapter is misidentified, then it might need cleaning or repair. Inspect MagSafe plug pogo pins. If middle pogo pin is dirty or sticky, then clean it or exercise it until it operates as it should. Inspect also MagSafe socket-inlet. If middle pogo pin (in MagSafe tip) is clean and springy, and middle land (in MagSafe inlet) is clean, then MagSafe plug is at fault.
How to fix it?
Get a replacement MagSafe plug or cable assembly, and splice it on. If you cannot find a used Original Apple MagSafe tip, then a non-authorised replica is acceptable. One will be better-off with a counterfeit tip spliced onto genuine power supply, than a knock-off power supply.
Do not discard a misidentified MagSafe power supply. It is still useful.
very similar problem, cross reference: 답변: MagSafe 2 is not charging, but keeps the power
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thanks a lot ! It worked with my magsafe 2 - 60w too. It was exceptionally satisfying to give back the new one I bought to the Apple store and get refund 89€
That's a good deed, Vianney ELOY. Good job!
댓글 달기
It’s probably just dirty. I took a toothbrush to mine when the light stopped working. Dirt gets in the corners and on the prongs. I have to do this every once in awhile, but it works every time!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had the exact same problem with my 60w magsafe 2 charger… it maintained battery level but wouldnt charge, and the Indicator diode was always off.
I just had succes heating the aluminum housing at the end of the cord with a hairdryer for a couple of minutes and then beating the end of the the cord into a hard surface with one medium hard hit. Now it works like out of the box.
Tried only heating it firstly but for me it was the beating that did the job.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Unbelievable
"and then beating the end of the the cord into a hard surface with one medium hard hit"
I did not use no hairdryer, just a medium hit against the floor, and it started charging again. Under "AC Charger information" the charger is detected after the hitting, the charging light came on and it keeps charging.
댓글 달기
답변을 추가하세요
John Dupont 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 53
전체 시간: 16,577
