주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
Understanding the Causes of UEFI/EFI Lockout
Hi,
So I am new to this arena and am trying to understand how the EFI lockout thing works. My particular machine is Macbook Air Mid 2012 (version 5,2), but I think this pertains to many older Macs. My understanding is that there is a hardware chip on the the Logic board of most Mac computers that verifies that a given processor matches the logic board, and is authentic/original. Does the check go any further, say, to verifying whether an OS or the SSD matches its original logic board or CPU? The implication being that if you took an SSD with an OS on it, and installed it in another computer, would you get locked out? What if you take a different logic board and put it into another computer, do you get locked out?
In general, what are the types of replacements or modifications to the computer that trigger the EFI lockout? With a locked out machine, is there a way of restoring it (say, by installing an SSD with a clean OS on it)? I am looking at logic board replacement for my Air and need to make sure I buy components that won't turn out to be bricks when I install them.
Thanks so much for your input!
D
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
EFI is the systems BIOS chip which also has a small user settable EROM that stores the hardware PIN if a user decides to set it. In the newest version of EFI iCloud lock has been added. In addition some hardware info is stored which is not alterable.
Given you have a MacBook Air you only have a removable SSD drive so there is no EFI involvement.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
dave white 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 520
