주요 콘텐츠로 건너뛰기
Water Spots on Screen, New LCD needed?
Hey, I spilt some orange soda over my 64GB itouch, and instantly went to flush it out with 90% isopropyl alcohol to get as much as I can off and out of any cracks or crevices. I successfully got the soda out, but some of the alcohol left these "bright blotches" on my screen. When reading on other forums, etc. I heard that it should evaporate and go away in a few days. It's been 3 weeks, and they're still there. If I open this up, could I let it air out or otherwise remove these markings? Or did I irreversibly damage the LCD screen?
I included pictures to show exactly what happened.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 2개
Did u find an answer anywhere??
Hi, do you find any solution for your problem?
댓글 달기
답변 2개
선택된 해법
The spots will not go away this is from water damage. If it bothers you you can replace it. I would wait until it fails or the glass gets broke to change it out, that way you dont damage the screen removing it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
First I would try opening up your iPod, and using a micro-fiber cloth to see if they will come off. If not, then you will need a new LCD which is not that expensive. Usually under $25.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Michael Dornisch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 2,338
