주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2610 질문 전체 보기
F-Series Vertical Green Line
Hey folks,
my F-Series Samsung (UE32F5570) got a vertical green line at a moments notice about a year and a half ago. About a half year ago I bought a new TV and never bothered about the old one until now. Okay so back to topic;
Is there any way to fix this TV without gambling or wasting too much money into it? I already opened the back of it and exchanged the ribbon connectors with each other on the T-Con board.
Oh and I removed both boards and baked them for 15 minutes at 200°C.
Kind regards
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello Krypton,
You are getting a green line on the side of the screen due to a bad connection on one of the flexible ribbon cables attached to the screen itself. In the area near where the line appears you will need to gently press on one of the ribbons while the set is on and you will find 1 spot where the line disappears. To fix this you can add some sort of foam to constantly press in that area. That should be the fix for it. Unfortunately there is no other way to fix it short of replacing the tv.
Good Luck!
Rich Lilja
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
krypt0n 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 3,548
