주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
Replaced battery 3 times due to swelling. Phone or Battery?
So I replaced the battery on the same iPhone 4 3 times due to battery swelling, first time was just the battery draining fast.
Is it just a bad batch of batteries or is it the phone causing the batteries to expand?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Did they all come from the same source? If so I suggest you ditch that source! I think I once had a battery, probably from a random eBay seller, which was swollen. That suggests a fault in manufacturing or storage can be a cause, on the other hand maybe it was a battery recovered from a scrap phone.
If the batteries were from different sources logic suggests it has to be the phone. I assume the swelling only occurred after a period of use? Batteryuniversity.com is the fount of all knowledge on batteries but I don't instantly see anything there about batteries swelling. Maybe the charger is charging it too fast? Check whether it gets warm on charging.
I'm not sure whether the battery protection circuity is in the battery or on the motherboard. Check the battery voltage immediately after a full charge, or if you can, while still charging once it gets above 95%. It should be no higher than 4.2V. And what is it when the battery is allowed to discharge until the phone shuts down? The protection circuitry should shut t off at between 2.2 and 2.9V.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Same supplier, going to stop doing iPhone 4 batteries for now. Too many issues.
댓글 달기
답변을 추가하세요
Ben 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,606
