주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
My controller moves on its own
My controller will make movements (looking and moving) without being touched. It is really annoying. I don't feel any stickyness in the joy sticks, they spring back good. what part should i replace?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 6개
가장 유용한 답변
Have you tried rebooting the console? sometimes if you start a game or something with the joystick not in the normal position it will think the normal position is the position it is currently in.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It is constant with 1 of my controllers. It never gets better. I can only use my "good controller" which i have marked now, lol. if someone uses the bad one it constantly drifts.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
its the dead zone dont let it be super FLIPPING STUPID just smash it with the handle of a screwdriver it worked for me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I thought my controller was broken, bought a new one and it still won't work. It keeps moving up and right making it impossible to sign in or use in general. I've done the hard reset and also unplugged it but no luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i have this too. happens on all four of my controllers, 2 are new.
댓글 달기
Yes dude this happened to me too and I don’t know what to do to fix it. All the controllers I connect do the same thing and I even bought a new one and it still moves on it’s own. Literally can’t even use my Xbox
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Your controller may be experiencing drift. One solution that often works is to open up the controller and apply a few drops of IPA in the joystick potentiometers to remove any dirt or debris affecting the joystick. If this does not solve the problem, then your joystick may be experiencing mechanical drift, which means the joystick needs to be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Doug Hoffer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 6,854
