주요 콘텐츠로 건너뛰기
The 12-inch screen laptop was first sold in mid-2006, and was considered well-equipped, powerful, and ultraportable.
5 질문 전체 보기
When I connect the laptop to the power it does not power on or charge
when i connect the laptop to the power ,does not power on or charge, the laptop work fine when the battery was have charge, but later stop work the power adapter, and i check the adapter and is does have power, what can be the problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
A very good chance that the jack/socket that your power adapter plugs into is loose or faulty. The easy test for this: Make sure your power adapter has electricity. Plug your power adapter into the jack on the laptop. While watching the power/charger indicator lights gently move the adapter's plug in the jack. If you can get either light to flicker or stay on the problem is the adapter jack/socket on the lap top. Not many people have the skills to replace this themselves. You may want to take it to a repair shop. If you believe this is a job you can tackle here is the part for a reasonable price.
http://www.amazon.com/OEM-POWER-M1210-M1...
Here is Dell's online service Manual for your laptop.
http://support.dell.com/support/edocs/sy...
해당 답변은 도움이 되었습니까?
점수 7
댓글 달기
귀하의 답변을 추가하세요
kitozo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,234
