주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Back camera on iPhone not working
A customer came into my shop to replace her back camera because it wasn't turning on and her flash wasn't working either. after replacing it, it still didn't work.
any ideas on what the problem is and what can fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Erin, I would say it is either the logic board or software. I would try to backup the customers data and wipe it. If you still have issues after factory reset then you know it is likely the logic board.
P.S. This may go without being said but make sure the connector is seated well. It can be tricky sometimes.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks, Jonathan I figured this but I didn't want to accepted it
I hear ya. Been there. Good luck to ya.
댓글 달기
  1. If torch light works and if the camera doesn't show it's camera or software complaint
  2. If torch light also doesn't works it's camera ic complaint ( it will be next to touch ID ic, next to touch ID connector terminal
  3. RC technologies
  4. 628002
  5. Rosel Corera
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same issue: My 6s+ was plagued with the shaky tracking issue everyone else has.
I bought a replacement and installed it. Now flash/led does not work and the camera is not recognized by any app. (Black screen). I reopened the phone and reinserted the OEM one… same issue. All connections are tight and everything is replaced as it should be.
I’ve reseated the ribbons 10 times (which each camera, old and new) and restored my phone to factory. No change.
Did I damage the board? I’ve seen a ton of these questions asked but the answers are always “reboot the phone” “reseat the cables”. That’s not the answer here.
What’s my next move?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's your camera ic is busted.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Erin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 17
전체 시간: 1,724
