주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
774 질문 전체 보기
Is the iFixit adhesive remover just isopropyl alcohol?
I am thinking about doing a keyboard replacement for my MacBook Pro but the battery must be pried off first. Instead of forcing it off, I found the adhesive remover in the store, but I’m hesitant to spend $33 for a solution that is similar to alcohol.
Has anything else worked for anyone?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 6개
선택된 답변
Hi @davchun
Watch the provided link and at 8 Second, pause,
https://www.youtube.com/watch?v=8krNjKEs...
It mentions contain Acetone
, etc almond fragrance....
해당 답변은 도움이 되었습니까?
점수 8
댓글 2개:
Check out aldon-chem website and search for sds, or google “aldon chem sds”. Chemical name “AA-0051”. The sds says it’s 99.8% acetone, 0.1% Cherry Almond Fragrance and 0.1% FD&C Blue #1 (C.I. No. 42090). It’s all public information.
댓글 달기
해당 답변은 도움이 되었습니까?
점수 6
댓글 달기
I went to Walgreens and get 100% acetone nail polish remover. It works
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I started using pure methanol a couple of years before iFixit found a solution.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I am thinking of replacing my macbook pro battery. Hesitant to buy an adhesive remover. But wouldn’t the acetone/nail polish remover damage or erode the old battery and causing problems?? I mean the old battery should be pretty fragile, I suppose..
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
[image|1948870]
yeah just go buy acetone lol
Acetone might affect the plastic covering but the actual battery cells are encased in metal. Acetone should be ok but I'd avoid nitric acid.
I replaced a battery just now and tried isopropyl alcohol (100%) on one side and acetone on the other side. I didn't find a lot of difference in how they removed the glue and I can say that both solvents struggled to dissolve it.
댓글 달기
Is it just Concentrated Windshield Washer Solvent with Ammonia?
해당 답변은 도움이 되었습니까?
점수 -1
댓글 1개:
google aldon chem sds and search for AA0051. it's a mix of acetone, fragrance and blue dye.
댓글 달기
귀하의 답변을 추가하세요
David Chun 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 42
30일 전: 139
전체 시간: 15,603
