주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
Is it safe to give corroded Xbox One board an alcohol bath?
Can I soak a Xbox One motherboard with corrosion in 90% rubbing alcohol? It has tough corrosion I can't get off with a wipe. Just wanted to make sure this was safe, thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hello Reed,
Yes it is totally safe to soak the board in alcohol so long as it is not energized. Be sure to air dry it or use a blow dryer on it to evaporate the alcohol before plugging it back in. Alcohol will not however do much to the corrosion itself but you probably should use a brush to loosen any corrosion while it is submerged. Do NOT use water at all, at anytime or the unit will not dry out very good and the corrosion will grow!
You could also use a pencil eraser to remove the corrosion.
Good luck, I hope this helps.
Rich Lilja
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I thought so! I appreciate the confirmation.
댓글 달기
Do you mean sticking the entire motherboard in isopropyl alcohol to soak? and for how long?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Reed Crosby 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 1,736
