주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
iPhone SE won't display after lightning connector replacement.
So I was wondering if I could get some advice. I opened up and replaced the lightning connector on the iPhone, but after testing it the headphone jack wasn't working. So I decided to open the iPhone again to see if there was a problem with which I installed the connector I found none. The problem is now the screen won't turn on and I have no idea if the connector got messed up or the screen is broken. I connected the iPhone to my laptop and iTunes detects the iPhone and even it's name, but I haven't been able to get any other response. I am stumped as to what the problem could be has anyone else had a similar issue?
P.S. I noticed that the cable battery cable seems to have some 'styrofoam' looking part in it and I don't know if it's relevant.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hey have you tested a hard reset?
Hold power button and home button the same time up to a minute, relese when you see the apple logo.
If that dosent work, I would open it up, relse the plate over the connectors for the battery and lightning and look if anything looks damaged on the board
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eli 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 36
