주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Washer does not agitate
i replaced the dogs already but the agitator just spins and makes a noise. When i pull up on the agitator the noise stops and it begins to agitate but then stops when i let it go
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
@indeep18 what is your washers complete model number?
@indeep18 it had the same symptoms before you replaced the dogs?
complete model # is 11026912691.
I dont recall if it was doing it before. I know the dogs were crumbling and so I thought that was all it was. After replacing them the washer did fine for a little bit but then all the agitator did was spin and wind the cloths around it. When i pulled up on the agitator it started to agitate and would as long as i was holding it up.
댓글 달기
답변 1개
가장 유용한 답변
Cause 1
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
UPDATE
You may be able to fix it with just an agitator kit -easy fix.
Here';s how:
https://www.youtube.com/watch?v=jCeSvQtB...
https://www.repairclinic.com/PartDetail/...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
The agitator moves but its like it slips. It turns backwards but then when i pull up on the agitator it starts to catch and begins to agitate.
댓글 달기
답변을 추가하세요
Austin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 691
