주요 콘텐츠로 건너뛰기
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 질문 전체 보기
Why does (only) the lower part of my touch screen not respond?
When I bought this phone second hand, the very low part of the touch screen would not repond, which did not bother me too much. At this at the point the screen had already been replaced one. Then i dropped it and needed another screen replacement. Ive tried three screens now, the first did not work at all, second would only lighten up if i loosened te screen from the frame. now the third shows the full screen, but only reponds to touch in the upper part. Am I just very unlucky with the screens they deliver or is there something wrong with all the screen I ordered? thanks for your help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Same thing with. Lower part of touch Screen is not working.
댓글 달기
답변 2개
가장 유용한 답변
Hey Albert, in my experience the Sony Xperia needs to be repaired by a proffesional. The xperia is not as easy as iT Seems.
Parts kan be detective to ofcourse. Double check al your connections and if possible talk to your supplier.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I regularly order aftermarket Sony screens, the only stock available in the US. I also order OEM Sony screens from a Sony authorized vendor in Europe. The Sony OEM often costs 5 times as much, so my customers rarely choose this option, despite my encouragement to go OEM.
The aftermarket screen out there really are not great quality. Defective digitizers are highly common. Glass quality is often poor too. Asahi Dragontrail Glass (a Gorilla Glass alternative) is only found on the OEM parts. Aftermaket is usually cheap tempered glass.
I have never seen a defective Sony Service Pack screen.
Regardless of which part you use, I recommend a professional familiar with Sony. Sony is basically the last brand learned by most repair texh in the US, so few even know what they are doing.
Definitely go to a place that can inspect your motherboard under a microscope first. It is entirely possible that the digtitzer connector on the motherboard is damaged due to the repeated mashing efforts of someone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Albert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 625
