주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Black screen illuminated
Hi all,
after a small crash into the floor, my MB shows a black screen with the backlight working. Everything sounds normal (fan, disk unit, hd, front light). Also I've tried resetting the SMC and PRAM.
It seems to be a connector unplugged from the motherboard but any suggestions please (graphics card crashed)?
Thanks in advance
Mario
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
First check RAM
- shared video RAM means if the RAM is unseated you could have this behavior.
If that doesn't fix it you're going to have to open it up and check the video cable connectors to the logic board...
Good Luck,
N.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
or to the LCD panel socket.
Hi,
I finally tried by checking each connector in the logic board and it worked.
Thanks you all.
댓글 달기
귀하의 답변을 추가하세요
Mario 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 1,642
