주요 콘텐츠로 건너뛰기
2016년 3월 Samsung에서 출시되었습니다. 모델 SM-G930V.
425 질문 전체 보기
Phone dies at 70% with new ifixit battery
Hi yall!
So I swapped out my phones battery with an ifixit replacement about 2 weeks ago and it was working great up until a few days ago. It just shuts down at around 70% and needs to be recharged from 0%. There was one time where I put it on the charger after it died and it would read 69% but would keep dying instantly unless it reached 70% capacity.
This happens multiple times a day and my phone is useless most of the day. Is there any way to fix this? I also still have the original Samsung battery but I bent it a little bit while removing it. Is the original battery safe for usage until this gets sorted?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Did you follow the instructions correctly that came with the new battery? Like charging it up to 100% and let it drain to 5% and then charge again?
댓글 달기
답변 3개
가장 유용한 답변
Battery is faulty. Lithium-ion batteries don't need calibration.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
OP, if you bought from iFixit, contact support (help.ifixit.com) and they should replace it.
댓글 달기
I am having issues as well. In the last few days is has been discharging fast. I am using the battery saving mode on phone but still dies fast. I had 18% this morning and it shut down. I have contacted support awaiting a reply. I installed this about two weeks ago along with a new camera lense glass.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Faulty battery send it back, You should get a refund
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jesus Valenzuela 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 785
