Kernel Panic with El Capitan and above
MD102LL/A 2.9GHz 8 GB RAM 500GB SSHD 13" Mid 2012
This is a strange one for me. It works just great with Mavericks 10.9.
I have tried it with several drives now and anything El Capitan and over causes a kernel panic. used different drives both internal and external with know good systems. Also downloaded new systems but I soon as I get to El Capitan it fails. Yes I tried High Sierra. This machine was not known for a GPU disorder but that is what I suspect (something in the dual graphics software). Has anyone like @danj seen this?
UPDATE 3/22
I started all over, new drive new cable. Downloaded new clean systems and installed Mountain Lion, Mavericks then Yosemite. Everything worked fine till El Capitan. Then I got the kernel panic screen and a reboot loop. No way to get to Activity our Terminal.
UPDATE 4/3/18
I contacted Apple support on this issue. After a couple of hours and call backs, I have managed to get Apple to better efforts to resolve this. I have uploaded the log to them and it is now going to the specialists for help. They told me they would get back to me within the week. I would not accept the answer of "send it in for a $357 depot repair" as it is a system software issue.
UPDATE 1/14/19
The problem turned out to be Apples’ installation software imposing APFS formatting on 3rd party SSHD drives.
I have found that for it to work on theses drives, you cannot just update, you have go in and reformat the drive APFS, then install a system, then migrate your old data.
좋은 질문 입니까?
댓글 3개
@mayer - Can you clear the log file of its history, then capture the event and paste crash report here as a PDF
Dan 의
Do you know what the firmware level is? Maybe it didn't get updated.
Dan 의
How are you installing these updates are they via the app store or from recovery, regardless of whats installed already instead of COMMAND +R
if u hold OPTION+COMMAND+R it will boot recovery for the latest os compatible with your mac try this instead i had loads of issues with using the app-store. Also at what point dose your mac kernal panic ?
=== Update (03/27/2018) ===
What happens if you try a windows 10 install ?
lewis Barker 의
