주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for Kenmore washing machines.
Washing Machine Defective Pressure Sensor?
We noticed during a wash cycle our washing machine (Kenmore Elite Model 79629278000, Top Load) displayed a ub message for an unbalanced load. We removed all of the clothing, drained the washer and attempted a second small load. The machine then proceeded to fill with water all the way to the very top an had difficulty spinning, even after some of the water drained 15 minutes into the load. I also noticed an odd / plastic smell when I removed the control face. Upon further research, I learned the most likely culprit is a bad pressure switch however, would this cause the unbalanced code to display, the difficulty in the machine spinning and or the strange smell? This will be our third repair in 3 years while my last Kenmore lasted over 20 years. At this point, if it is a board, computer interface or such, the repairs will add up to more than the cost of the washer. Thanks in advance for the help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
First, make sure after the washer has finished the agitation cycles that it drains all the water first before the motor pauses and then begins to spin. If it's attempting to spin with a full tub of water it will eventually cause the clutch bands to wear out sooner than normal. The result could cause a lack of torque and friction to release the brake on the basket drive and begin spinning. Based on your symptom, the clutch will likely need to be replaced.
In order to remove and replace the clutch, the agitator must be taken out, the washer cabinet must be taken off, remove the drain pump and motor and the gear case.
First,
disconnect the power cord from the power source.
Pry the agitator cap off and remove the bolt located down inside the agitator.
Lift the agitator off.
Remove the left and right side end cap covers (key#14 and 11) and remove the screws at the bottom of both end caps.
Slide the console towards the front of the washer, lift it up and hinge it over the rear panel.
Pry the two gold colored cabinet clips off from the top of the washer.
Disconnect the three wire lid switch harness plug from the top of the washer.
Tilt the top of the washer cabinet towards the front and walk the cabinet straight out from the base and set it out of the way.
Pry the pump clips off and slide the pump off the motor and pivot the pump (leaving hoses attached) over to the left side of the motor.
Remove the motor mounting clips by prying them off (if a screw is threaded through the clips, remove the screws first).
Disconnect the motor harness connector and remove the motor.
Lean the washer up against the wall and remove the three gear case bolts.
Pull the gear case down and remove it from under the washer.
The clutch will be sitting on top of the gear case.
You should not have to remove the basket drive shaft. When the clutch torques and spins around it strikes the clutch engagement cam which causes the brake pads to come in and release so that the clutch can spin the basket drive shaft and basket.
Reverse the procedure to reassemble your washer. See images below. The clutch lining and spring is part #285790 which is available at
Sears Parts Direct
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Justin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 629
