주요 콘텐츠로 건너뛰기
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 질문 전체 보기
Black spots on tv and getting double image..
I have a 70" 3 yr old vizio tv. Turned it on one day and had big black spots in the corners and a double horizontal picture. Not sure if I should keep it or try repairing it, I just don't know what the problem could be. Someone told me my LED screen may be bad and you can't buy replacements, is that correct?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Often, with bad screens it's not even worth fixing. However, this looks more like an image issue to me, considering the double image. Can you give me the model number so I can look at the boards that TV has? One of them is probably the issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
It' a Vizio E701i-A3E smart TV, thank you....
Ok, so sounds like this is a very common problem with your model. It was actually recalled by Vizio back in 2013 - you might call and see if they are still doing free repair or replacement. This would be ideal because it would be free and you wouldn't have to worry about accidentally damaging something.
855-209-4106
https://hdguru.com/vizio-issues-a-recall...
I'm going to call Vizio first thing and ask. If by chance they won't honor the recall do you think I should replace the circuit boards inside seeing it may be just a bad chip?
Did they honor it? If not they might be able to tell you exactly where the issue would be.
댓글 달기
귀하의 답변을 추가하세요
Mark Grant 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 1,867
