주요 콘텐츠로 건너뛰기
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
27 질문 전체 보기
Telesccopic lens will not retract on the Coolpix S7000
Telescopic lens will not retract when camera is turned on or off. The entire telescopic lens stays extended.
Error message says "Lens error. Try again after turning the camera off and on".
I have tried to remove the battery, memory stick, turned on off multiple times.
Thank you,
Jeff
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
There are a few simple things you can try documented at https://therestartproject.org/wiki/Compa... but if none of those work then I'm afraid you may be out of luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Jeff 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 331
