주요 콘텐츠로 건너뛰기
Aluminum Apple Wired Keyboard
209 질문 전체 보기
Left Shift + E not working (Right Shift + E works)
Hello everybody,
I have a strange Problem with my second hand A1243 (With Swiss Layout) Keyboard.
If I use left Shift + E it doesn't do anything, but if I use right Shift + E it works.
Everything else works so far.
Has anybody any idea what that could cause?
Thanks in advance.
Sandro
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
did you spill something on it?
No, I just got it second hand. Perhaps the previous owner spilled something.
댓글 달기
답변 3개
선택된 답변
Hello Everyone
Sorry for coming back to you so late and thanks for your inputs.
It started working again. But I’m not sure on what the problem was.
I have two possibilities:
1) Because of my work I’m using various softwares that have system-wide shortcuts (like Spectacle for window rearrangement). I have reinstalled some of them. Maybe these shortcuts for english keyboards had a binding that was not working with the Swiss keyboard.
2) Around the same time it stopped working, I have updated my Laptop. While uninstalling the softwares mentioned above, I updated the laptop again and also reseted the NVRAM/PRAM.
One thing that stands out (I don’t believe it was the problem though) is that the the bottom left of the chassis of the keyboard had a small bump in it. Between the alt and cmd keys. I flattened it out with my fingers but I don’t think this was the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Try left Shift for other purpose eg to Capitalize or other to check if it pressed.
If it is ok, you can change the keyboard layout in mac settings.
http://thetypingcat.com/howto/change-you...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I testet every other Left-shift Combination with the keyboard.
The layout setting ist also in Swiss-German (I tried German too).
It happens only with Left-shift + E
Strange! change it to English layout to check it. Also check it on another PC if it possible or check it on windows with boot camp or virtual machine.
댓글 달기
I’m having this exact issue. The computer is a 27” iMac, the keyboard is an apple USB keyboard with keypad. It’s only the letter E, and only with the left shift key. I’ve checked the system preferences > keyboard > shortcuts area and I don’t see anything there.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Did you had luck with your keyboard?
As I mentioned above I updated the system, reseted the NVRAM/PRAM and looked at other software with system wide shortcuts.
댓글 달기
귀하의 답변을 추가하세요
Sandro Ciotti 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 18
전체 시간: 1,565
