주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
upgrading to a SSD
I have 27" Late 2009 iMac.
Can I replace original 1TB HDD with 1TB SSD?
Update (03/24/2018)
My only lingering worry is how to handle temperature sensor for the HDD.
Obviously SSD will not have temperature sensor, so what should I do with the temperature sensor for HDD?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
There is external sensor on the kit to put it on top of ssd.
댓글 달기
답변 2개
선택된 해법
Sure you can! Follow this IFIXIT guide: iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement and here's the needed tools and parts: iMac Intel 21.5" and 27" (Late 2009-Mid 2010) SSD Upgrade Kit
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21" and 27" Late 2009-Mid 2010 with this SSD upgrade kit. 이미지
제품
$122.99
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yes you can do it if you can afford it,
But the 1 tb SSD will be little expensive and a caddy to fit it...
You can buy a smaller ssd and a dvd to hdd caddy and replace the dvd with new ssd (depending on your time)if you are not using the dvd any more...
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Actually the one iFixit was selling (out of stock now) was not that bad on price: [링크된 제품이 누락 또는 비활성화 됨: IF107-132]
The kit cost for a 1 TB is $389.99
Yes , iFixit prices is good , and the 500gb ssd kit is in stock!
You can make you old one Usb external.... and keep your dvd drive!
댓글 달기
답변을 추가하세요
ikim20012 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 583
