주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
300 질문 전체 보기
Flashing Folder NO RECOVERY PARTITION
Hey guys, I’m kinda in a pickle. I have an SSD as my main boot but for some reason I don’t have a recovery partition. So it’s beyond my reign of Mac Knowledge. I have a Windows 7 PC is there anyway I can use iTunes or something to reinstall El Capitan or do I just need to use my friends 2009 recovery to reinstall it
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You'll need to create a OS installer drive from your friends Mac. Here's how: How to create a bootable macOS Sierra installer drive
Independent of creating the installer you'll need to replace the HD SATA cable as I doubt your SSD went South on its own. In fact I wouldn't be surprised if after replacing the cable your system startup up! Here's the IFIXIT guide: MacBook Pro 15" Unibody Mid 2009 Hard Drive Cable Replacement The newer version of this cabe (2012 model) is a better cable I would recommend putting it in. Here's the part: MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable The reason this happens is the rough surface of the aluminum uppercase wears the cable. Even still I recommend you apply electricians tape on the upper case where the cabe rests to offer additional protection and don't over bend the folds!
Once you get the cable replaced see it the system boots up on its own. If it does you really want to make a backup ASAP! (TimeMachine). Then using the OS installer drive reformat the drive and install a fresh copy of MacOS, then restore your backup that way your files are safe.
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
While waiting on the answer I flipped my drives (I installed one with the disc drive attachment) and it booted, I probably accidentally damaged the cable
댓글 달기
귀하의 답변을 추가하세요
Jesse Moore 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 532
