주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for top and front loading Whirlpool brand washers.
Washer will sometimes not drain
I have a WTW8900BCO washer that sometimes will not drain. Each time I will pull the drain pump and reinstall and it works fine for a few days before not draining again. The drain hoses are clear. The unit is 4 years old. What do you think?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
This washer is direct drive so there is no belt. I am thinking it may be a electrical malfunction of some sort.
Is it noisy?
No it is not noisy. I hear humming for about a minute that sounds like the drain pump is trying to start. Then the Ld indicator light comes on. When I put it in diagnostic mode it shows F32. Both of these mean long drain
댓글 달기
답변 1개
have you tried changing the belt ? if it is stretched you're most likely to get this problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jsreece 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 90
