주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s No Service/Line Searching iTunes ERROR -1
Hye I got n IPhone 5s sent in to me for repair. The customer claim that his IPhone having a No Service issue, and after restore iTunes got an error -1.
So my question is should I reball the BB CPU first ? After reball, what should I do if the problem not solved ? Cuz I read some thread on the internet saying that error -1 is not only because of BB CPU, some of them said its because of BB PMIC. How should I know which one is the right solution ??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 5개:
do you get the imei when you dial *#06#
How can I get the imei number if the phone are stuck in itunes logo
it doesnt say in your question that its stuck on connect to itunes, try using 3utools to kick it off recovery or if that doesnt work try flashing the ipsw
lol. this is not a software issue, this is hardware bro. im pretty sure its hardware
If it's stuck in a iTunes recovery logo loop at least try to exit recovery mode via 3uTools.
It probably can still boot up if it didn't start flashing the firmware on there yet.
Then you can check what he said in the comments.
댓글 달기
답변 1개
Error -1 may be caused by connection problem, network connection or hardware issue.
About hardware problem, probably check the baseband.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Azim WHITE 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 579
