주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Made by GM. It's the eighth generation of a land yacht!
How do I change the turn signal switch?
I've got no headlights and after changing the headlight switch to no avail I started changing my attention to the turn signal switch. I noticed it doesn't click when operated. So I need to know how to remove it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Do the wipers work?
댓글 달기
답변 2개
선택된 해법
Disconnect your main battery and let it sit for and hour then reconnect and see if the problem persists. (This does a reset)
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Worth a try--can't hurt and the price is right.
댓글 달기
Before you disconnect the battery, make sure your ECC (Electronic Climate Control, if you have that option) is turned OFF.
The ECC computer has a program flaw that causes it to overcycle the blend valve motor when seeking its original setting after you hook up the battery, which usually results in a broken gear inside the blend valve actuator. Then you have no control over A/C or Heat, the blend flap usually defaults to A/C which means no heat ever. Replacement of the blend valve actuator is awkward at best and very expensive at worst (most shops will take apart the entire dash to get access). Or if you are very inventive you can make a hillbilly workaround by disconnecting the actuator arm through the back of the glove box, and rig a manual control from coat hanger wire (not elegant).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ron 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 2,993
