주요 콘텐츠로 건너뛰기
Based on the third generation Legacy, the Outback became its own model and the Legacy SUS remained unique to North America, and was realigned with the Outback Limited package, offering the sedan, with an optional horizontal six-cylinder engine, also optional on the wagon.
Do I have to use Subaru parts
I have recently swindled into buying a Subaru Outback and the man said that he had done all these relairs on the car. I bought the car but the repair receipt was forged. I am now trying to piece this car together but I keep getting told I have to use Subaru parts from the factory. Do all the parts need to come from the factory or can I use offbrand valve cover gaskets and fuel pumps?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
No, you do not need to use genuine parts. That is a myth. Aftermarket parts are just as good if not better than genuine parts. However in saying that, stay away from anything that comes that looks cheap.This example is something I would buy, due to the fact that the money is OK and it comes with all the necessary parts.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Alright thanks. I already had this mechanic shop charge me $700 for a cadalitic converter so it’s nice to know I can fix some of this on my own.
My Subaru expert (former dealer shop foreman) says that he has not had success with any CV axle assemblies except OEM Subaru.
댓글 달기
First, this is an excellent question and one that I often grapple with. I currently own a 2001 and 2003 Outback and have removed and repaired almost every movable part on these cars; Front and rear struts, ball joints, inner and outer tie rods, brakes, rotors, center differential, most front and rear bushings on both cars, alternator bearings, rebuild power steering pump, engine rebuild down to splitting the block, etc. OK, now that you know where I am coming from, here is what I do:
For most of the parts, I use OEM parts for several reasons. First, I tell myself, without any evidence, that the manufacturer knows how the cars wear and OEM parts are likely to have been updated to match known issues. The bearings in the center differential are an example of this kind of update where the thickness of the race has been modified significantly to deal with a known problem. The second reason is fear of counterfeits and the wide variety of quality in aftermarket parts. I have no doubt that some aftermarket parts are far superior than the OEM parts but I have also, far too often, dealt with aftermarket parts that have been manufactured to fit many applications but actually fit none of them as well as an OEM part. And if you search for information about counterfeit automotive parts, you will find that almost everything that is sold by a big brand name, e.g. NGK, SKF (bearings), Bosch, etc., has a counterfeit counterpart. The third reason I go with OEM is because I shop online and often the cost of the parts online are not horrible, even compared with aftermarket parts. An example of this is with a recent strut replacement. I bought OEM struts for my 2003 Outback. The struts were marked KYB so I asked myself how much I would pay for KYBs purchased as aftermarket. I found that the price of KYBs at Autozone were about the same as what I paid at https://www.subarupartsdeal.com/. Struts could be found for less on Amazon but I have a high fear of counterfeits so I only compared the price against the price at a big chain. By the way, I typically have time to allow a car to sit if I have to order a part so I avoid buying parts from the dealer unless it is an extreme emergency. My local dealership typically charges anywhere between 50% to 100% OVER MSRP for parts, especially small parts, and this is not atypical. Finally, since I am performing the work myself, I am already saving a bundle so I don’t feel so bad spending a little extra on OEM parts.
Now some specific comments:
  1. I would probably buy aftermarket bearings if I could be sure of the provenance (where it came from)
  2. Aftermarket rotors are probably OK but the selection has always confused me.
  3. I like to buy the OEM brake pad kits because they come with new retention springs and anti-squeal grease
  4. I use OEM oil filters. I used to use aftermarket but was convinced that the OEMs are better. Online, I pay $4.67 each for OEM so why not. When I order, I usually buy a number of them, 10 or so, and buy new drain plug crush washers at the same time.
  5. Buying new axles is painful. I have purchased a new axle and a remanufactured. The re-man had the hole for the retention pin drilled off-center. I will not buy re-man again. I don’t know if I will buy OEM or aftermarket. One of my cars has aftermarket and it seems to be OK.
Sorry if this does not completely answer your question but I hope it helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sam heodt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 811
