주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.53 GHz Core 2 Duo 프로세서
170 질문 전체 보기
Replace the full unibody
Hello,
I´m wondering if you can help me on the following mater:
I own a Macbook Pro 15", 2.53, mid 2009 A1286, currently with a damaged hinge. The glass opens just a little bit everytime I close the shell.
Nonetheless it closes completely and, most importantly it works just fine.
However, I came across this used macbook and I dont know if it is fully compatible with mine.
Do you think it is possible to install my entire macbook on the used shell?
Are they the same on the inside? the screwwholes and all that?
Alternatively, do you thing I could just remove the screen + top shell and place it into mine? Will it fit?
Thank youuu
MY MABCOOK PRO IS THIS ONE:
https://everymac.com/systems/apple/macbo...
USED MACBOOK I FOUND ONLINE:
https://www.olx.pt/anuncio/mac-book-pro-...
COMPARISON BETWEEN BOTH MODELS, WHICH IM NOT QUALIFIED TO ANALYSE:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The hinges are replaceable! It's a lot less work replacing the hinges than swapping out parts between two systems.
The process is the same as replacing the display following this IFIXIT guide: MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Display Assembly Replacement. Once you get the display off you can slide the Clutch cover off to gain access to the hinge screws on the lid assembly. Then you can take them off. Make sure you use the correct sized bit and you may need some solvent to loosen the sealer. Sometimes I find a soldering Iron can heat up the screw to loosen the thread lock that some have.
Here's the parts you'll need
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ricardo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 46
