주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Is my phone screen fixable? (Please Read Description)
Hi,
I dropped my phone bad on its face and when I picked it up there was a black splotch on one side of the screen and vertical green and purple lines covering a decent portion of that same half of the phone as well as the bottom half of the screen being greatly faded. On the left side, some of the touch screen wasn't really usable at all and the screen would shake and reflect the top half onto the bottom half so I would be sort of seeing double. I thought it would be somewhat functional but when I started trying to use it, buttons would press themselves and the lines and splotches have expanded onto most of the screen by this point. Obviously the inside LED or whatever is busted, is that at all fixable or do I need a completely new phone?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
If you could post some photos that would be very helpful. 기존 질문에 이미지 추가하기
댓글 달기
답변 2개
가장 유용한 답변
Well the good news is this is definitely fixable. What I would do is replace the Display: iPhone 6s Screen Replacement
Part: iPhone 6s Screen
That is a pretty simple and most fixable part on your iPhone! Hope this helps and have fun with the repair. Contact me if you have any issues.
iPhone 6s Screen 이미지
상품
iPhone 6s Screen
$59.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You just need a screen replacement and it will fix your problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Matthew White 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,560
