이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Unplug the machine, open it up, and remove the PRAM battery. Wait awhile (min 15 mins; I'd leave it that way for longer). Test the PRAM battery to make sure it's still good, or just replace it if you aren't sure since it's cheap enough.
While you're there, check the power supply for swelling caps and replace as necessary.
Put it all back together and try to power it up.
Steve 의
