nut keeps coming loose on the grinder
the nut that hold the grinding wheel in place keeps coming loose. how do I fix it?
좋은 질문 입니까?
좋은 질문 입니까?
There should be two 'nuts' one is a locator and the other is the locker. If it is a 100mm grinder you can only use 100mm disks and nothing bigger. Make sure that the locking nut is placed on correctly and when you tighten it down, try to spin the wheel. If you can hand spin it, then you have either the locator or the locker on the wrong way.
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 14
30일 전: 53
전체 시간: 3,363
