주요 콘텐츠로 건너뛰기
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 질문 전체 보기
Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
댓글 달기
답변 2개
선택된 답변
The broadcast Pix slate G 1000 is not a typical computer. This is a highly customized machine with proprietary hardware for broadcast television video. I suggest posting on their forum for an answer.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i will post there
댓글 달기
가장 유용한 답변
If you just Google for your brand of motherboard suffixed by "beep codes" you may well find the answer.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I can't it's a special motherboard made by the computer company that is the same one that made the computer.( The pc is a switcher)
댓글 달기
귀하의 답변을 추가하세요
McOfficialPlayYT 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 118
