주요 콘텐츠로 건너뛰기
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
How To Replace Just Glass on ZTE Zmax Pro Z982
so i shattered my phone screen an ordered just the glass replacement someone help or do i have to order the screen and digitizer??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi,
If you haven’t got equipment to do glass only refurbishment, it is highly recommended that you order a full display, as most phones these days have the display and glass/digitiser fused. :-)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The glass and the LCD display are two different parts on this phone and can be replaced separately. The digitizer is built into the LCD, so if you only cracked the glass in front don’t order the $40+ dollar full LCD assembly. You can order just the glass on Amazon. A warning, though, replacing this can be difficult. A good option would be to look up some videos on Youtube on how to replace the glass and decide from there whether or not you want to go through the trouble, otherwise most cell phone repair stores will still work with you if you bring in your own replacement parts, it will save you a few bucks doing it this way.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kali Killa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 6
전체 시간: 2,016
