주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
The phone keeps restarting in 3min intervals and heating
Hello,
i got a dysfunctional Iphone 5s from my friend, who said he couldn't use it anymore because it kept restarting. Formerly he thought it was a battery, which we changed. But then it was getting worse, it was uncontrollable, it was just possible to extract the data via cable.
Now what it does, restarts in approximately constant 03:30 sec intervals, while the bottom right quadrant(viewed from the side of the display) is getting considerably hot over time. I can still operate it within the boundaries of locked Apple ID and factory reset(set up a wifi connection etc)
I can imagine there is a hardware issue, but does anybody has a clue which part is to change ?
any advice will be appreciated.
thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
was this phone in water by any chance-there isn't a simple part to change if it is over heating there is a short on the logic board-this requires someone that can microsolder to inspect for damage. The battery was replaced so I am going with components knocked of by the battery connection when it was pried out. take a picture of the battery connection.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shrubbery 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 86
