이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Need to have the carburetor overhauled. Part of the process is to soak all components in ;carburetor cleaner', then use compressed air and blow out all passages. This will dissolve the trash/obstruction that's causing the problem.
I have another problem. When trying to use the' recoil starter' it fails to engage. I have to physically rotate the crankshaft and bang on the housing.
Robert Hanna 의
